Hello,
I have 2 of those flip face changing thomas trains and 3 Remotes.
1 Train when you turn it on via the trains on/off switch works on its own without the remote, when turned on, it stays on, and works, but when you try to use any of the 3 remotes I have, it does not control the train in any way. All 3 remotes make the sounds etc via the buttons.
2 The 2nd train, when you use the on switch from the train itself, it does not work or move at all, neither does it work via any of the 3 remotes at all.
I know the remotes have an on/off switch underneath them, they are all set too On as well.
Do these trains only work with their specific remote ? as in what they originally came with ?
I am trying to work out whether all 3 of my remotes are buggered somehow or 1 or 2 of the trains are :/
The train that does not work at all when you use the on/off switch from the train itself, has a red light the will flash when you take out or put in a battery into the train itself. So I presume it is not completely dead ?
Any thoughts or idea's ?
