That's fine, but you'll have to make some cosmetic changes like changing the running board to 90 degrees, altering the shape of the tanks, removing the rear dome and adding Ashima's oil tank (which is technically redundant since she runs on coal). And please remember not to use flash and to turn the lights on in the room when the photos will be taken. Also, be sure to do the best job you can so she'll be pretty like she's meant to be. Good luck.
