Hi Ripley
Of course this helps me. Strange as there is a difference. Thank you very much for taking the time to help me out. Was there only two weights in yours? Might there also been weights in the chassis? Mine had four at least there were four in the container I use for parts of an individual train I am working on. Since it sometimes takes months for me to start and finish a mod I guess I shout start adding a small note card too as now I don't know if I added the two extra weights or not. My shell also did not have the two outer panels for your weights. Looking at your picture I can see that the screw shat for the face plate also works as a stop for those weights so since mine no longer has a face It looks like I will create a custom weight for the front to fit mine. I just need to make sure I have the proper weight and not to much or to little as that whole front unit will be permanently affixed. I wonder if anyone else might have a different configuration on their Ben or Bill?
Many thanks Ripley!
