Hi
I tried to swap a stronger torque motor to this series, so they can run a bit more smooth on different brand wooden tracks. But I was surprised by how difficult to open it, can anyone give me some insight?
Test subject: Percy
First difficult: triangle screws! I finally able to order a 2mm triangle screw driver to open it. You can also grind a nail or triangle needle file to make it work.
Open:
Open 2:
Here is where I got stuck. I remove both screws that put the housing together, but I cannot remove the wheel! It seems I must destroy the wheel in order to open the entire chassis.
Further, there is a circuit board on top of the motor also surprised me. Not sure if you can see from below picture:
Anyone has any tool in mind or guess how the manufacturer's worker did it? Did they glue the wheels to the axis or did they force fit it? Put it in a freezer? Any suggestions?
