like super, i prefer the blue track because it offers more of a free build. its also been around a lot longer, so easier to find used for not much money. theres also more track pieces, like auto switching points, to bring variety to a layout.
trackmaster, in particular the current range, is very restrictive. if you buy a set, thats almost all it can be used for... that set and nothing else. some of the components are incompatible with older engines, too.
similaraly with some of the later original trackmaster sets, like castle quest, zip zoom and logging adventure etc. they have some curves that are twisted slightly so will only work in that configuration.
dont get me wrong, some early trackmaster stuff can be incorportated, like the tidmouth turntable and such, and most of it looks really good. you just have be careful and check what it is you are buying. if you arent sure, check here and we can advise you. nothing worse than spending good money on a set thats near impossible to use.
you can buy tomy to trackmaster adapters, but they arent overly common or cheap, either. maybe spend some time on google, check out different sets and special track pieces from each range and decide from there. if you decide to bite the bullet and start buying from japan, blue track is cheap there, its the fees and shipping that bump the overall price right up.
