Back on topic of the Blue EF63’s.. so the two sound units I mentioned earlier are back up and going an all functions are working. I guess I just love the challenge but these are right on par with being as complex as he TnA engines.
I was able to use the switch from the other unit that I had which seems to have additional issues, but has been good for parts. I also swapped shells since it had a less abused shell. I may eventually paint the other shell as it could be interchangeable.
Here are a couple more reference pics Incase it may help someone.
Switch wires back up and connected to the circuit board:
This is showing the small with piece which goes under the gear, I was not seeing where this came from, then took the other engine appart very carefully and saw it to figured I better document it.
Speaker compartment, there is a weight that goes in here.
I will hopefully get a video up soon with both sound units running over her. I think it should sound pretty cool. 😃
