leylandvictory2 wrote
Can your TNA Gordon moves under its own power on a straight surface? It looks like your Gordon can't even move under its own power on a flat surface.
yes it can, straight track and hard floor, just not curves very well or hills.
Okay, SO The axel spins inside the gear when the on switch is in off or on position, BUT When it turns on, The axel moves with the gear just as normal, Its like its strength is weak tho. Any explaination?
Also he when I am holding it, Has no issues rotating the wheels and the axel and cog gear e.t.c move as normal so what the heck is this?
Well, Crap pretty noticable crack, In the gear visible on the wheel, I can reach in there without taking him apart with superglue on a little pointy tool, Should that do the trick?
its big enough I could just probably fill it in, Could I do that with some superglue?
