no problem :-) i believe 3 volts is the minimum the they need. mine came attached to a green battery box which was setup for 4.5 volts, i took out the little circuit board that had the power button on it, did a little soldering to get the terminals off and connected wires for a single battery instead. the holes don't have light in them, its just shining thru. i imagine you can cut them but i just bunched them up tightly, cut out a little out of middle of the tender and stuck them in.
