So last night I was wondering what might happen if I took out the motor in my Flying Scotsman (Trackmaster Revolution) and replaced it with the motor from a Tomy Duck chassis, as while doing some cleaning and repair to my TOMY Mavis I noticed that the motors are nearly identical in size. Well, I have good news and bad news. The good news is that the "surgery" was a success, and Flying Scotsman now moves at about the same speed as the Turbo Thomas, which is just delightful to see- I will post a video for you all to look at on my Youtube channel next weekend. The bad news is that while removing Duck's motor from the motor casing, the anti-tampering tabs popped open and his motor and gears fell apart. Luckily, I have all the parts including the spring, but I have no clue how it all fits together. I was thinking I would reassemble the entire mechanism with the TM2 motor inside Duck, just to see what happens. as if it doesn't work properly I'll be needing a new Duck model for filming. Any help you guys can give me about how to reassemble the Duck motor mechanism would be great!
