I watched your video, but it cut off before I got to see what it was that I was looking for...
99% of the time ours works fine, but every once in a while it does what yours is doing.
I was concerned about it, and probably did all the same checks that you’ve already done, (man those are some BIG delicate gears inside!!) and fiddled around with some testing too. So what I wanted to see was what I had noticed, is that when the turntable doesn’t immediately return, and seems like it’s going to block Terrence, he will bump into it just hard enough to trigger its return, then he enters and goes about his business.
How does yours react to him bumping into it??
I just looked at our video, and if you look closely, what I described actually happens @1:39 in the video above!!!
