here is the blurb on this years must have AFX set ....
Â
Product Manual: 10722004.PDFÂ
[size=small]Toyota and Audi go head to head in the 24 Hour Champions set from AFX. Two of the most impressive cars ever to compete at Le Mans, the Toyota TS040 and the Audi R18 bring staggering hybrid horsepower to the classic race.[/size]
[size=small]Wonderfully efficient aerodynamically, both cars were a singular challenge for AFX when creating them in 1/64[sup]th[/sup] scale. In fact, they are the most complex bodies we have ever made. The Audi has 15 full depth body openings â way more than we or anyone else has ever done.[/size]
[size=small]With these stunning cars, 12 different track layouts to choose from, and an AFX Exclusive Photo Realistic Pit Building, you can recreate the excitement of Le Mans right in your home![/size]
[size=small]Â INCLUDES
AFX Exclusive Mega G+ Race System
The easiest slot car system to learn on and drive at the limit with the lowest, lightest, best-handling chassis anywhere. Made up of our new Mega G+ Chassis, Upgraded AFX120 Controllers and Exclusive Tri-Power Pack, the Mega G+ Race System is the perfect balance of grip and speed.[/size]
[size=small]AFX Exclusive Tri-Power Pack
Adjustable power levels allow all drivers, regardless of skill, to get the most out of their race! Changing levels is as simple as flipping a switch. At full throttle through every turn you can expect the following:[/size]
[size=small]Beginner (8v):Â Stay on track about 95% of the time
Intermediate (12v):Â Stay on track about 60% of the time
Expert (22v):Â Youâre on your own![/size]
[size=small]Â FEATURES
See Instruction Manual PDF for detailed inventory[/size]
[size=small]30 feet of the best track you can buy â AFX track is easy to use, high quality and reliable[/size]
size=small Mega G+ 1/64[sup]th[/sup] scale slot cars[/size]
size=small Tune-up Kit â Keep your cars running strong[/size]
size=small 22 volt Tri-Power Pack â Compare to the 17 volts in other peopleâs sets[/size]
size=small AFX120 Controllers â Upgraded for easy drivability[/size]
size=small Photo Realistic Pit Building[/size]
[size=small]Â MEGA G+ CHASSIS
This new Mega G+ chassis doesnât just go faster or handle better than the competition. And it doesnât just have the ultra-low, narrow dimensions of the original Mega G to continue the reign of the most realistic HO cars on earth. Itâs smoother, more consistent, and more intuitive than any car weâve ever built.[/size]
FN20 Advanced Power Unit: lighter, smoother, quieter, more consistent and uses 33% less energy than Mega-G
Weight: Up to 35% lighter than any other HO chassis, 5% lighter than Mega-G
Shape: Narrowest, lowest chassis ever made for more realistic bodies
Pick-Up Shoes: Stronger, follows rail better for consistent power
Center of gravity: Lowest of all competitors to corner with confidence
Guide Pin: AFX Exclusive Extra-long tapered guide pin keeps the car on track longer
Ground Effects Magnets: Level 30 Neodymium â Stays glued to the track
Chassis Material: Super durable Nylatron has just enough flex
Brushes: High carbon power unit brushes last longer than composite brushes
New Redundant Power Transfer System: Maintains consistent power supply to motor for improved durability and drivability[/size]
[size=small]Â MEGA G+ RACE SYSTEM
We wanted wheel to wheel racing, lap after lap, the feel of driving a real car. But we couldnât do it by just changing the chassis. We had to create a whole new systemâŚMade up of our new Mega G+ Chassis, Upgraded AFX120 Controllers and Exclusive Tri-Power Pack, the Mega G+ Race System is the perfect balance of grip and speed. With decades of slot car innovation and over a year of experimentation, this is the best out of the box slot car system you can buy.[/size]
