Ah, it's interesting you'd mention this 🙂
The latest version of the Mabeee battery that can be used to control Plarail and other battery operated devices can actually be operated and programmed via Scratch, which I believe can be used on Arduino?
In any case, I have actually been working on [theoretical] plans as to how I could automate my Plarail layout using a combination of sensors, Mabeee battery controllers, and of course, Scratch programming, with the ultimate aim to be the creation of a form of ATO train control system wherein Scratch would drive the trains, with the sensors regulating distance between trains, and stopping positions.
Equally, I am also considering using Scratch, the Mabeee system, and a USB controller kit to potentially enable me to create and build a train driving controller based on the layout of a train driving desk, with sound buttons, power handles, etc., allowing for a fully immersive Plarail driving experience.
If and when I can prove these concepts [presently, I have one Mabeee battery underway from Japan with a consignment of other Plarail goodies], then I'll be sure to post my findings; Indeed, should I be able to create a successful Plarail ATO system for the Mabeee/Scratch, or a USB controller for PC-based driving control, I'll share the progams and schematics on here so you guys can potentially build your own controller, or easily program your own layout 🙂
Incidentally, here's a link to the Mabeee batteries that I bought - These apparently should be the latest model, compatible with 'MabeeeDesktopEX'; effectively a piece of software that allows one to connect to Mabeee batteries via PC. Previous models could not do this, but could connect via a Japan-only mobile app. These newer models are still compatible with the app as well, but the PC software is not region-locked, and as long as you can install 'DesktopEX', then you should be able to sync it to Scratch and go from there.
https://www.jauce.com/rakuten/item/kazamidori:10014457/
I will try and find the link to the pages that explain how it can be connected and incorporated into Scratch, and post a translation to here [the pages are mostly in Japanese] 🙂
