Super wrote
Hi Nigel is the TPU material lesser than PLA? Is it too soft, hard to work with, not paintable or more expensive?
Hi Super,
TPU is not lesser than PLA, I'd rather just describe it as different. You know what PLA is like as you've handled that. TPU is more like a plastic rubber for want of a better description. It can be a bit harder to work with as it is a bit more temperature sensitive when making things and can suffer from stringing. Where it excels is like rubber it is pretty flexible and can be bent or whatever you need. It is great for making tyres, gaskets and flexible parts in general. Once printed it can't really be sanded and the surface is never really smooth like TPU which is why from the photo's I thought maybe it was TPU. It is also quite a bit more expensive, but this is mainly due to the fact its not used as much as PLA so lower sales mean higher price per unit.
chrisjo wrote
The listing says they are made from "vegetable PLA", so basically that's just PLA.
Indeed it is if that is what the advert says. All standard PLA is basically made from vegetables, corn starch is the main ingredient which is why it is biodegradable. The only time it changes is if it is a PLA+ as they are often a mix of PLA and other products like ABS which is derived from oil.
